Ignition cable
Old Marine Engine » Stuart Turner » Ignition cable « Previous Next »
Steve Acert
Username: sentinel997
Posted on Monday, July 14, 2008 - 02:54 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello, can someone tell my what a cable to be installed between sparking and ignition-coil.
With or without reinstatement (kOhm)?
Roy Jones
Username: royjones
Post Number: 16
Posted on Saturday, July 19, 2008 - 02:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Steve,
I had a problem with my P66 missing and replaced the leads with steel wire ones after realising the other new ones were only carbon coated string inside to carry the current. The S/T relatively low voltage (compared to modern electronic ignitions) needs hard wire circuit. Cheers, Roy
Post Number: 855
Posted on Saturday, July 19, 2008 - 05:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Don't use the fancy fabric coated old style pattern from the old engine supply folks. The least little bit of moisture causes them to short externally till completly dry. I use coper coated steel with black rubber insulation.
I am quite sure Lee Pederson ships internationally.
Be sure to order black no woven jacket
Lee Pederson
There are pics near the bottom of the link below that you can see the shiny black high tension wire from Lee.
click here
