P55 water inlet altering.
Old Marine Engine » Stuart Turner » P55 water inlet altering. « Previous Next »
Matthew Balkwell
Username: matt
Post Number: 89
Posted on Tuesday, February 03, 2009 - 04:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This is just a thought, but has anyone ever plugged up the cooling water entry at the top of the exhaust outlet and made the entry for the water on the side of the expansion chamber cover plate in one of the drain/inspection plugs.
I have seen pics of Stuarts fitted with thermostats having this as a bypass system.
If this works it would solve the problem of the exhaust outlet rusting out and eliminate two water tight joints.
Matt and Ron.
Peter Ogborne
Username: peterogborne
Post Number: 289
Posted on Tuesday, February 03, 2009 - 06:37 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think the manufacturer knew what they were doing when the designed the water cooling system. Preheating the water before it hit the cylinder block has probably prevented a lot of cracked blocks.
