Stuart R2 pumper
Old Marine Engine » Stuart Turner » Stuart R2 pumper « Previous Next »
Mike Hodgson
Username: orwot
Post Number: 26
Posted on Friday, March 28, 2008 - 10:12 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I've added another R2 pumper to my collection
Pictures and low res video on ---
http://good-times.webshots.com/album/562868618lnLgqM
Mike.H.
Howard Lyne
Username: umborne
Posted on Monday, April 28, 2008 - 09:41 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mike, I acquired a pumping set just like the one in your photograph a couple of years ago, but have only just got around to looking at it. Mine has a rotary magneto but gives no spark. It appears that Fairways Marine is out of business (temporarily we hope) at the moment, so any ideas about dating? Its serial number is R2 30773. Any info about WICO rotary mags too?
ian albrighton
Username: dulux
Posted on Tuesday, February 03, 2009 - 11:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi howard
ive just restored a stuart r2 lighting plant with a wico ign system. i found that it was not a mag as such but a coil and a set of points which you power by battery. the flywheel had never had magnets on it its a 1934 model plant no 30088
Mike Hodgson
Username: orwot
Post Number: 48
Posted on Tuesday, February 03, 2009 - 01:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The Wico flywheel magneto should have the magnets
on the crank and not the flywheel.Your engine has been converted to coil at some time.
For Wico rotary magneto information go to--
http://www.oldengine.org/members/diesel/WicoMagneto/MagData4.htm
Mike.H. http://groups.yahoo.com/group/stinfoexchange/
