Stuart Turner - 2 stroke - magneto
Old Marine Engine » Stuart Turner » Stuart Turner - 2 stroke - magneto « Previous Next »
Reckle
Posted on Sunday, February 27, 2005 - 07:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 30 foot keeler. i can get the engine to run and idle for hours. When it is put into gear it dies. It has been serviced recently. The water sump has smashed so a bypass with a filter has been put in.
timmulvey
Username: timmulvey
Post Number: 135
Posted on Monday, February 28, 2005 - 05:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I would think that you have a fuel problem. Check that the throttle linkages from the throttle control column to the carby are set correctly. Is there sufficient fuel getting to the carby - any kinks/partial blockages in the line? Does the carby spit when you put it under load by engaging gear??
Why do you think the water/cooling may be related??
peterogborne
Username: peterogborne
Post Number: 235
Posted on Monday, February 28, 2005 - 07:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I would also check your exhaust system...the pipes and muffler may be coked up, these engines like to ''breathe''
Trudie Dudfield
Posted on Saturday, April 04, 2009 - 09:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I live in new zealand in a place called Omokoroa in the bay of plenty. I have a 10hp Stuart Turner two styroke marineengine which has been running in the workshop,and I am looking to sell. Can you help.?
Andrew Smith
Username: andy_smith
Posted on Saturday, April 18, 2009 - 06:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sound like an air lock or blockage in the fuel system. There's enough trickling bye to keep it running at idle, yet as soon as you apply load, and the demand for fuel increases it splutters to a halt. The fule line must run in one continuous fall from tank to the carb.
If it's a float type carb check the float is vertical and isn't jammed.
