Stuart Turner 8hp - Essex UK service ...
Old Marine Engine » Stuart Turner » Stuart Turner 8hp - Essex UK service needed « Previous Next »
Stephen Hills
Username: evaannie
Posted on Thursday, October 15, 2009 - 06:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1960's Dauntless with a twin-cylinder 8hp two-stroke Stuart Turner engine which has become unreliable. It will tick over and rev fine, and run for a short while under load, but then gradually fade and stop. Sometimes it will take a while before it starts again. I am not mechanically minded. Can anyone recommend an engineer in Essex, UK, who would have a look at the engine in the boat for me ? (Or is there an obvious cause of the unreliability ?) Many thanks, Stephen
terence david harris
Username: t_d_harris
Posted on Friday, December 11, 2009 - 05:45 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Stephen,,easy enough,check fuel,clean carb,make sure fuel getting through,sounds like fuel prob tho,
