Stuart p55 ? help
Old Marine Engine » Stuart Turner » Stuart p55 ? help « Previous Next »
graham rylah
Username: airbourne
Posted on Friday, July 02, 2010 - 05:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi all i am new to marine engines and just aquired a p55 i think and told by prevous owner it is 8hp the only id tag is on gearbox and says 20b217 , it is fitted with brass solex carb and has two small coils and points , and is hand start , this is were i have a major problem , the bottom chain sprocket is siezsed solid and i do not have a manuel and have no idear how to remove , the crank turnes but both sproket and gear which flywheel engages to are rusted solid , and marlex marine have not got parts i need so have run out of idears any help or advise welcome as this is my first restoration of a marine engine regards to all graham
George Martin
Posted on Saturday, July 03, 2010 - 09:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Usually the coils and points variety were P66 and had dynastart or starter and generator I think.
However to unsieze sprocket:-
remove flywheel-
undo nut
hold lever pressure on left hand side between flywheel outer and engine, clump r/h side with clump hammer, it should spring off.
clean up sprocket with wire brush and carefully remove circlip (if its there).
Warm up sprocket with blowtorch, not too hot, squirt with easing oil, repeat several times.
Using a hard block of wood and hammer on a tooth attempt to turn the sprocket. repeat all the above sevaral times and it should free off to a loose fit.
The centifugal latches should be a simple task to refurbish.
I'm sure I can find another sprocket if you ruin it.
The centre part is crankcase, so big problems if you break that off!.
graham rylah
Username: airbourne
Posted on Saturday, July 03, 2010 - 05:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
thankyou very much for reply , i will try that tommorow , also can anybody tell me were i can obtain a chain or will a motor bike chain or similer fit regards and thankyou
George Martin
Posted on Sunday, July 04, 2010 - 09:28 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Standard chain fit, its 1/2" x 3/16" I seem to remember. Just measure the distance between the rollers and the width of the sprocket.
graham rylah
Username: airbourne
Posted on Sunday, July 04, 2010 - 07:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
thankyou george for your help , it worked but it held on to the last, no damage to cast but the gear is shot , so if you have one how much is it with postage , i took the head of today the water ways were blocked and took side cover off water jacket have never seen so much rubbish i dont think when this engine was running the water did not go round engine that well many thanks regards graham
George Martin
Posted on Monday, July 05, 2010 - 02:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I found 3 in the engine shed!
email me at:- a1941.h(at)tesco.net and I will get in touch directly
