Crankshaft seals
Old Marine Engine » Stuart Turner » Crankshaft seals « Previous Next »
Paul Vecovsky
Username: paulvec
Post Number: 15
Posted on Tuesday, December 07, 2010 - 04:59 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
well this has to be the holy grail for stuarts! the make or break of them and the resulting use as anchor blocks! Fuels have changed and the modern additives ruin the old seals causing starting & running issues especially when warm!
ST fitted synthetic rubber seals [part no 1485] to replacing the previous collar & ring on the older engines.
Now the catch-new oil seals are made of nitrile and are not fuel resistant so what's needed are viton oil seals which are fuel & oil resistant but off course hard to obtain in imperial measurements! Metric are obtainable but are slightly larger in size!
Imperial- 2"outer 1.5 inch inner
Metric- 52mm outer 38mm inner
Anyone had any experience with these and found a supplier?
thanks paul
John Archibald
Username: john_archibald
Post Number: 160
Posted on Tuesday, December 07, 2010 - 05:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You may be able to find Viton seals at www.mcmaster.com which is based in the U.S. and will take credit cards even for small purchases.
Good luck,
Archibald
Northfield, Minnesota
John Archibald
Post Number: 161
Posted on Tuesday, December 07, 2010 - 05:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have also found an SKF site online:
http://www.skf.com/portal/skf/home/products?maincatalogue=1&lang=en&newlink=4_1_ 40
Archibald
