Leaking rear gearbox seal P66 wisdom...
Old Marine Engine » Stuart Turner » Leaking rear gearbox seal P66 wisdom req « Previous Next »
clive beswick
Username: clivebes
Posted on Saturday, May 16, 2009 - 05:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
my problem is , aknowledging i have to change the seal is The gearbox appears to be arelatively new type ie FLAT DIRECT DRIVE , HORIZONTAL FOR N AFT SHIFT not mentioned in the P66 manual can anyone profer drgs or describe how to change the seal on this particular model?pic attached
steven john page
Username: fairbanks
Post Number: 102
Posted on Friday, December 14, 2012 - 10:30 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Clive, if its the "73" gearbox you talking about then i have a manual. if you can give me your e-mail address i will try and send a copy. regards steve.
