Stuart P66 Transmission
Old Marine Engine » Stuart Turner » Stuart P66 Transmission « Previous Next »
Dana Hayman
Username: dana
Post Number: 25
Posted on Friday, November 29, 2019 - 10:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello, I just pick up a Stuart P66, there are two problems, first the transmission lever will not move, second is that you can only move the flywheel about 30 degrees. I removed the head and it looks clean in the piston area. Any suggestion on fixing problems ?
Dana
