Stuart Turner Gaskets
Old Marine Engine » Stuart Turner » Stuart Turner Gaskets « Previous Next »
David Ewart Schofield
Posted on Friday, August 22, 2008 - 05:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have lots of various gaskets for both singles and twins, but only head gaskets for the R3M. If any one is intrested I intend to stock P5 and R3M,s in soft copper, these are re-usable.
David Schofield.
James Gabriel
Username: 1942jamesg
Posted on Tuesday, August 26, 2008 - 02:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi David
I would be interested in a complete gasket set for a P5 including head gasket and crankshaft oilseals
Regards James Gabriel
Jon Lewis
Username: spinning_props
Post Number: 14
Posted on Thursday, September 18, 2008 - 07:15 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello David
I'd also be interested in head gaskets for the R3M type engine.
I thought I better declare an interest to try and boost your customer base!
Jon
AHill
Posted on Sunday, September 28, 2008 - 04:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Would be over the moon at being able to get hold of a P5 head gasket!
Any information on buying one would be be appreciated.
Post Number: 662
Posted on Monday, September 29, 2008 - 08:49 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I was desperete to find a US source of old style compressible copper head and exhaust gaskets. I finally gave up ever finding a US source. I don't remember now how I found
www.gasketstogo.com John Baker in Thailand makes them . If you have a pattern to copy his prices are reasonalbe and the work of good quality. For the record I have no commercial or other interest in his business.
Colin Ashton
Username: colin_ashton
Posted on Thursday, November 13, 2008 - 07:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I would be interested in a full set of gaskets for a full restoration on a P4 (No. 11011) and information as to where I may source Big End Bearings and a brass Carburetter.
Posted on Thursday, December 04, 2008 - 08:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Everyone. I have now got in stock solid copper head gaskets for P4/5,s and R3M,s. Also some base gaskets for P5,s plus other assorted gaskets for these engines. I have a number of R3m,s for spares or overhaul plus some reconditioned Lucas and Wico mags. Please e-mail or phone me upto 10pm. (01793 771699)
Graham Jeffery
Username: grahamj
Posted on Monday, January 19, 2009 - 04:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello I am after spares for an R2 lighting set, main bearings, crankshaft oil seals, ring set (std) and a gasket set. Any help in locating these spares would be appreciated. Graham.
David Myers
Username: dave_myers
Post Number: 59
Posted on Monday, January 19, 2009 - 05:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Graham,
Marlex Marine have taken over the Fairways stock of Stuart spares and can be found at..
http://www.stuartturnermarine.co.uk/
Hope this is of help,
Dave
Philip Thornton-Evison
Username: hotbulb
Posted on Tuesday, January 20, 2009 - 10:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This company can supply good quality bearings at reasonable prices.
http://www.vintagebearings.co.uk/homepage.htm
The mains are RMS7, and the bearing on the output shaft is an RMS6.
I'm in the process of sourcing oil seals and will post again when I have more details.
Regards
Philip
george martin
Posted on Wednesday, January 21, 2009 - 04:54 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Seals are available everywhere. I used these people. The mains are available and chap 1 1/4M type, but unsure about the quality.
http://simplybearings.co.uk/shop/index.php?cPath=19_4462
or this one is cheaper
1.25x2x0.37 inch Single Lip Nitrile Rubber Metric
Big-end is more of a problem though.
Neville Phaure
Username: neville4
Posted on Wednesday, January 21, 2009 - 07:39 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi I am looking for a cork rockerbox gasket for a DAF 575 engine.
I am based in Kent, UK
Regards
Neville
steve palmer
Posted on Monday, August 15, 2016 - 03:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi every body,can any one help me with locating a solid state regulator/rectifier to directly replace the old car type regulator used on my stuart turner dynostart.Thanks a million Steve
Peter Fowden
Username: skippy
Posted on Wednesday, December 06, 2017 - 02:38 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can you supply me with a full set of gaskets for a rm3 and post to Belgium .. also looking for a manual.. or atleast no wot the head tightening torque .Rg setting rare .regards peter
Peter A Forbes
Username: listerdiesel
Post Number: 30
Posted on Saturday, December 30, 2017 - 05:33 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Marlex Marine sold their spares, drawings and casting patterns to us this year.
We have moved the spares to our own storage and will be compiling stock lists as soon as we can.
Do to existing arrangements between one of our gasket suppliers and David Schofield we will be sourcing gasket replacements in the UK.
Once we have all the parts checked and catalogued we will post here again.
We also have the Stuart-Turner production day books, so can date engines from their serial number.
Peter
Robert
Username: robert
Post Number: 916
Posted on Thursday, January 04, 2018 - 04:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Updated link:
http://vintagebearings.co.uk/
