P5M 4H/P
Old Marine Engine » Stuart Turner » P5M 4H/P « Previous Next »
boyd guard
Posted on Tuesday, May 17, 2005 - 12:33 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have p5m, need a parts and o/haul manual. S/n of eng. is 67228. Can anyone help please.
mike_sutcliffe
Username: mike_sutcliffe
Post Number: 7
Posted on Tuesday, May 17, 2005 - 03:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi boyd,
I can help with photocopies the manual and other interesting information. Please email me with your postal address.
Mike
timmulvey
Username: timmulvey
Post Number: 151
Posted on Tuesday, May 17, 2005 - 07:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Boyd - can you recheck the engine no. as it isn't covered by the ranges of engine nos. on my list. Also, I sent you a pic of a dipstick so you can fabricate youself. Email me if you want exact dimensions.
chris_davies
Username: chris_davies
Posted on Saturday, July 09, 2005 - 07:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i have a p5m what is the correct spark plug gap as i renewed the plug and am getting a misfire which i did not have before and also what is correct ratio fuel mix and recommended 2 stroke oil
mike_sutcliffe
Post Number: 11
Posted on Saturday, July 09, 2005 - 07:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Chris, I use a Champion L86C which replaces the Champion L14 or UJ12Y as specified in the manual. Ask your local supplier what he has which is equivilent. A KLG F50 is OK as well.
The Fuel mixture specified is 1 in 48 or 50. That is 100 ml of oil to 5 litres of petrol. I always use premium grade fuel as it lasts longer than ULP if not all used up. I have found that Outboard grade oil which is designed for water cooled engines works better than mower type two stroke oil in that there is very little oil residue in the exhaust.
Do you have a P5 manual??
Mike
mike_sutcliffe
Post Number: 12
Posted on Saturday, July 09, 2005 - 07:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Chris,
The correct spark plug gap is .025 inches or .60 mm for both magneto and coil ignition.
Mike
mike_sutcliffe
Post Number: 13
Posted on Tuesday, July 12, 2005 - 12:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Chris,
I just checked my box of spark plugs and notice that the last plugs I purchased for the P5 are Champion D16. They seem to work very well and are quite cheap.
Cheers, Mike
chris davies
Posted on Monday, May 15, 2006 - 02:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
can anyone advise approximately how many turns the brass air filter should be opened on a p5m as a guideline to starting as i have cleaned the main jet and unsure of the correct setting
Peter Ogborne
Username: peterogborne
Post Number: 133
Posted on Monday, May 15, 2006 - 05:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Chris ....start at about 6mm [1/4 inch] and then decrease it until running is ok. Any more than 6mm and it will be too lean.
