R3MC Water Pump
Old Marine Engine » Stuart Turner » R3MC Water Pump « Previous Next »
Chris Lewis
Username: chrislewis72
Posted on Sunday, March 29, 2009 - 12:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,
I have a R3MC in a small 12ft clinker. Had it running well last summer, and gave it a full winterise. However having successfully restarted her first time this weekend, she isnt pumping water through. The pump is doing its job in terms of movement, however it isnt passing water through.
Having opened the pump, there is a lot of grease inside. Is this meant to be there? nothing has ceased, its a puzzle.....?!
Any ideas as to why? Any help appreciated.
Chris
David Stott
Username: david_stott
Post Number: 33
Posted on Sunday, March 29, 2009 - 06:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have you primed it with water through the caps on top of the pump? Somtimes the non-return valves do not seat properly and the pump has trouble pumping air. Give it a drink and all may be fine.
Chris Lewis
Posted on Monday, March 30, 2009 - 11:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
David, thanks for this. When i get out of this damn office, i'll give that a try....!
Chris Lewis
Posted on Wednesday, April 22, 2009 - 06:49 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
David, thanks for your help on this, tried her at the weekend and she was pumping a treat. rgds
