P6 gearbox adjustment
Old Marine Engine » Stuart Turner » P6 gearbox adjustment « Previous Next »
Rufus Craze
Posted on Wednesday, May 02, 2018 - 04:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi, just finished rebuilding a p6 that now runs beautifully but the gearbox is running slightly in astern when in the neutral position. Neutral can be found by pushing the selector slightly into ahead. Is there a way of adjusting this? Thanks!
Rufus Craze
Posted on Tuesday, May 15, 2018 - 05:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Don't worry, I found it!
Undo the four bolts holding on the selector shaft and use the small pin bolt to adjust backwards and forwards.
Sweet!
