Blaxland master pup parts
Old Marine Engine » Blaxland » Blaxland master pup parts « Previous Next »
kyle bennett
Username: kylebt
Posted on Friday, January 28, 2011 - 05:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi i am looking for a fuel connection fitting for my Blaxland putt putt fuel tank
Putt Putt fuel tankPutt Putt fuel tank 2
Laurie Derwent
Username: laurie_d
Post Number: 84
Posted on Friday, January 28, 2011 - 08:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Kyle, That looks a bit sad. If you are not worried about keeping it original you could try finding a fuel tap from an old lawn mower (Victa or similar). The old ones were brass (now they are plastic or they just don't fit a tap)and I have used one for several years. I also find that outboard type fuel hose is more practical than copper. Good luck with it. Lauris
ross deutschbein
Username: rossde
Post Number: 10
Posted on Saturday, January 29, 2011 - 01:38 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
try a plumbing supply store like Reese, most of these fittings are plumbing threads. you will find them helpful there
