Blaxland 5/7 twin
Old Marine Engine » Blaxland » Blaxland 5/7 twin « Previous Next »
Stef
Username: ssilent11
Posted on Sunday, September 12, 2010 - 02:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have play from left to right in crank. What is the max. play allowed at thrustrace end.
Many thanks
quinton wilkinson
Username: qwilkin
Post Number: 21
Posted on Sunday, September 12, 2010 - 03:30 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ring Blaxland Marine in NSW tel 0265583182 they are very helpfull and still make the engine
Quinton
David Myers
Username: dave_myers
Post Number: 89
Posted on Sunday, September 12, 2010 - 03:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You should know better than that Stef.
Ring Boyd or Todd. If you need the number, ring me..
What do you mean by Left to Right? Is it sideways or Front to Back end float. If it is Front to back you should have 10 - 12 thou, (thats what it is on the Hall anyay). If it is sideways then the bearings are flogged.
Hope all is well, Give Suzy a hug from me.
Cheers, Dave
Murray
Posted on Sunday, September 12, 2010 - 04:12 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If it helps, as it sounds like you need to pull it down, the crank to white metal bearing clearance should be 2 thou.
Stef
Username: ssilent11
Posted on Sunday, September 12, 2010 - 04:38 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Dave, conclusion is slight movement to be taken up by forward thrust from prop.
