Magneto
Old Marine Engine » Blaxland » Magneto « Previous Next »
Michael
Username: mdm01
Post Number: 10
Posted on Monday, January 27, 2014 - 01:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,I have a magneto which came on a pup sxt and I think it is the original. It has the contact points on the top under a round metal cap held in place by a metal clip. I am looking for the little carbon brush with spring and the plastic fitting that the high tension lead goes into on the magneto. I have attached some pictures, any suggestions where I can get these? Thanks Michael
magneto and parts
John Burchell
Username: ml115
Post Number: 10
Posted on Tuesday, March 04, 2014 - 10:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Michael,
Take the parts to your local electrical tool repair/motor rewinder. There will probably be a very near match in his stock.
Regards John
john fuller
Username: scooter
Post Number: 31
Posted on Tuesday, March 04, 2014 - 10:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Michael
Have you tried, The Maggy Man, If you Google him you'll find him.
Regards
John
Michael
Username: mdm01
Post Number: 11
Posted on Wednesday, April 02, 2014 - 05:21 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks John and John, I managed to get the parts from a vintage motor cycle parts seller.
Regards Michael
Llewelyn Sweatman
Posted on Friday, April 27, 2018 - 10:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi all, just bought a Blaxland pup and need some bits.. Magneto drive, magneto and piston rings.. Any one can help with this ???
