Two unknown engines
Old Marine Engine » Unknown Engines - post here with photos » Two unknown engines « Previous Next »
Steve Roskowski
Username: modhydro
Post Number: 9
Posted on Tuesday, February 20, 2007 - 11:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'd sure appreciate any help that anyone can offer.
The single's jug is 4 3/4" in diamter and its top is 10 3/4" above the crank centerline. The flywheel is 13 1/4" diamater by 2 1/4" wide. The cylinder and crankcase is all one casting with one side being a bolt on cover.
The twin has jugs 5 1/2" x 12 7/8 tall from the crank centerline.
I have some more photos and can send these in higher resolution if it helps anyone out.
Thanks in advance for any info you can provide.
Post Number: 1428
Posted on Tuesday, February 20, 2007 - 07:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The twin doesn't appear to me to be a marine engine ? Maybe equipment or auto engine ?
Steve Roskowski
Username: modhydro
Post Number: 10
Posted on Thursday, March 22, 2007 - 04:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Has anyone had any thoughts on this single? I'd sure like to find out what I've got so I can restore it properly.
Steve
