Need help w/identity evinrude handi-twin
Old Marine Engine » Unknown Engines - post here with photos » Need help w/identity evinrude handi-twin « Previous Next »
eric palmer
Username: eric_p
Posted on Thursday, June 23, 2011 - 06:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
the numbers from plate are 4212-00525. looking for age,size,and fuel mix.
Dave Lockwood Jr.
Username: dgjr
Posted on Saturday, June 25, 2011 - 02:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My sources say it's a 1937 Handitwin; 2-1/2 HP. Fuel mix calls for 1/3 pt. per gal. of 40W
oil. I'd suggest 1/2 pt. per gal. of the modern
TCW-2 or 3. This thing has bronze bushings throughout; no rollers or needles. Really does need a "thick" mix.
Spark plug recommendation was originally for a Champion C7; a "warm" plug; gapped at .025.
Currently available plugs would be a Champion D16 (#516); Ac #C86 - if you can find them; or
NGK AB-6 (2910). Be sure to use a NON-resistor
plug; in case someone tries to sell you a plug
of some other number. Manufacturers are moving toward a one size fits many applications mentality - doesn't work well with this old stuff.
The shear pin was an aluminum item; 3/16" x
15/16". Not a nail, as is often found in its place. Oh, point setting is .020".
