Identity?
Old Marine Engine » Unknown Engines - post here with photos » Identity? « Previous Next »
rbprice
Posted on Monday, May 24, 2004 - 08:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can someone plse identify this engine?
Posted on Tuesday, May 25, 2004 - 08:07 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Quite sure it started life as a Caille Liberty drive outboard. I don't think the flywheel is what came on it from the factory.
solarrog
Posted on Tuesday, May 25, 2004 - 11:45 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
although the cylinder does look Caille the block does not. The liberty single has flanges that stick out horizontially This block does not. There were other manufactors of the same style
outboards. Gopher, Gierholtt(Hess), I think its a Heins 57. Please keep us posted.
rbprice
Posted on Tuesday, May 25, 2004 - 07:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Well - in my 1917 Caille catalog on page 30 there is a picture of a Caille Liberty engine that sure looks a lot like this one. As Ernie points out, the flywheel is not right for a Liberty but the flanges and the pivot point are very similar.
The seller thought it was a Gray but that is obviously wrong. Here is a link to the eBay item
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2479205501&sspagename=STRK%3AMEDW%3AIT
you can look for yourself and see what you think.
Cheers
solarrog
Posted on Tuesday, May 25, 2004 - 08:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have 5 of the liberty singles here, none of the blocks look like this one. The cylinder does.
I guess there is a model I do not have
Posted on Wednesday, May 26, 2004 - 11:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This could also be a regualr Caille outboard. I looked at one last saturday. Kind of like an Evinrude rowboat motor.
Take a look at this page
http://caille.8m.com/
