Who can identify this old engine buil...
Old Marine Engine » Unknown Engines - post here with photos » Who can identify this old engine builder's shop photo? « Previous Next »
Robert
Posted on Sunday, April 14, 2002 - 02:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Or more precisely, the cylinders castings sitting on the floor? Bottoms around bolt holes look like Corliss, but can't be sure. (Andrew: will send you the photo if you could add it here please & thank you!)
Posted on Sunday, April 14, 2002 - 06:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is Robert's photo:
shop
Robert
Posted on Tuesday, April 16, 2002 - 10:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is almost the full photo. A friend who is a marine engineer and old engine collector tells me that the cylinders are for a two cycle and the piston in the lathe is definitely for a diesel, which narrows the field somewhat. One of the West Coast builders perhaps?
Unknown
