Buda Engine but what model
Old Marine Engine » Unknown Engines - post here with photos » Buda Engine but what model « Previous Next »
Ryan Gee
Posted on Thursday, January 15, 2009 - 11:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I hope this is an easy one for you. These engines are in a 48' boat from 1926. They may have been the replacement for the original gas engines that the boat came with.
Can you tell me what model they are?
Thank you,
Ryan
Ryan Gee
Posted on Thursday, January 15, 2009 - 11:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Picture didn't come through. Let me try that again.
Thank you
Andrew Menkart
Moderator
Username: andrew
Post Number: 987
Posted on Friday, January 16, 2009 - 09:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Is there any nameplate data on the engine? Buda made a lot of different models of 6 cylinder inline diesels.
Any idea what year those engine were installed?
Ryan Gee
Posted on Friday, January 16, 2009 - 01:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The Boat is in San Francisco and I am in Southern California. I wont be up to see the boat again for a few weeks and wanted to do a little research on the engines.
I do have a few more photos I could post that might help.
Lawrence T Wolfe
Username: larry_from_maryland
Post Number: 336
Posted on Friday, January 16, 2009 - 06:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Your engines have the old style heads and oil filter. When allis bought buda in the fiftys they started redesigning the engines useing heads with the injectors pointing down. Lots of the budas i have seen that were sold by other companys do not have good markings on them. They can be hard to id. You can get the numbers off the injector pump and get a injector pump repair place to look them up for you.
Jim Staib
Username: drrot
Post Number: 15
Posted on Saturday, January 17, 2009 - 08:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have you tried looking up the boat in an old Lloyds Register? They post the engine details.
steve morgan
Username: rockyrowed
Posted on Friday, November 12, 2010 - 01:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i have a 90hp inline 6 diesel buda-allis-challmers model 6damr273 the tag has these names and info the thing is the tag is in a hard spot to see on mine its lower than the head on the side of the block on the port side id have to look again seems like theres two tags heres a phone number to buda if you need one louisana,usa 318-222-3348
