Crankcase drain cock
Old Marine Engine » Atlantic - Lunenburg Foundry » Crankcase drain cock « Previous Next »
Roger Shields
Username: rshields
Posted on Thursday, May 28, 2015 - 02:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I saw a picture of an Acadia 4 hp that had a drain cock mounted on the low point of the crankcase, I assume to drain excess fuel from flooding? Any ideas if this can be retro installed on a 4 HP Atlantic?
Post Number: 2077
Posted on Friday, May 29, 2015 - 07:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sure just drill and tap for 1/8 or 1/4 pipe. What ever size drain cock you plan to use.
If the engine is together use grease on the drill and then on the tap to catch the metal chips
Hope this helps
