A method for starting 6 volt engines...
Old Marine Engine » Timers, Magnetos, Ignition » A method for starting 6 volt engines on 12 volt « Previous Next »
Moderator
Username: andrew
Post Number: 954
Posted on Friday, October 29, 2004 - 09:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Miro has sent in a description and diagram for using 12 volts to start a 6 volt engine, without converting everything to 12 volt. Should be very useful. Thanks Miro.
quote:
Andrew, I finally put together the notes for the 12V start on 6V engines. Thought you'd be interested. I've sent it to a number of the guys. It's actually quite simple, straightforward , and much like an old marine engine.
Miro Forest
It is attached in PDF format (click the Miro link below). You will need the free Adobe Acrobat Reader on you computer to view it.
Miro's 12 volt starting description
