Four cycle engines
Old Marine Engine » Miscellaneous » Four cycle engines « Previous Next »
david_woodworth
Username: david_woodworth
Post Number: 23
Posted on Friday, December 30, 2016 - 04:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
How brands of four cycle engines were made before 1915? I am looking for one. I would like to locate one about 8 hp two cylinder. Thanks for your help. Happy New Year. May your boat float and engine keep running through the new year.
Post Number: 1269
Posted on Friday, December 30, 2016 - 10:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
An 8hp 4 stroke from this era was generally a heavy engine. My 1905 Union 8HP weighs 1200lbs. A 5hp Buffalo is probably 600lbs. Later engines were lighter, 1920 5hp Lockwood Ash 4 stroke is probably under 200lbs.
david_woodworth
Post Number: 24
Posted on Saturday, December 31, 2016 - 12:44 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks JB. It looks like aluminum Pistons won't help much.
