ODINE ENGINE
Old Marine Engine » Miscellaneous » ODINE ENGINE « Previous Next »
angilly
Username: angilly
Posted on Friday, June 10, 2005 - 01:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
looking for info on a engine that I have, lable says ODINE MFG. Co. castings all start with '9V'
folowed by three digets.
any info as to what this might be used for or when???
Fly wheel is about 10" engine 20" long
Small 3 blade 6" fan cooled radiator on top of water jacket
HELP!!!
larry_from_maryland
Username: larry_from_maryland
Post Number: 237
Posted on Friday, June 10, 2005 - 07:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You couldn't find an M in front of the odine anywhere? Modine was one of the largest radiator makers.
angilly
Username: angilly
Posted on Saturday, June 11, 2005 - 05:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I took some photos, not that it all together, hope this might spark someones memory.
angilly
Username: angilly
Posted on Saturday, June 11, 2005 - 06:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
sorry file was to big heres the photo
Post Number: 507
Posted on Saturday, June 11, 2005 - 08:27 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It's a Coldwell Cub lawnmower engine.
Hope this helps
angilly
Username: angilly
Posted on Sunday, June 12, 2005 - 09:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks all I also showed this photo and got the same info at a show yesterday. What a great group!
Now dose any one have info on the correct color and maby a digital copy of a maintance manual??
Hope you can help, I was told it should be red.
larry_from_maryland
Post Number: 239
Posted on Sunday, June 12, 2005 - 08:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The place to go would be harry's old engine site there are a number of posts in the archives about this engine.you can go to WWW.ATIS.net then click on links then scrol down to his site.
