Champion Blue Ribbon
Old Marine Engine » Timers, Magnetos, Ignition » Champion Blue Ribbon « Previous Next »
Bob Segneri
Username: bob54
Posted on Thursday, September 08, 2016 - 07:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
As the tile says I have a Champion Blue Ribbon motor. During disassembly I found that the coil has several cracks in the case that I am sure will cause it not to work. I read in another post that the ignition system can be updated with a Briggs and Stratton magatron. Is there a part number I should be looking for, and is the installation as simple as the directions say,or will I need to fabricate a bracket for it to work.
