19' sharpie with a Gray Marine engine...
Old Marine Engine » Boats with Early Inboards » 19' sharpie with a Gray Marine engine « Previous Next »
admin
Board Administrator
Username: admin
Post Number: 95
Posted on Thursday, April 27, 2023 - 10:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Posting this for Michael:
I stopped by today and checked out a 19' sharpie with a Gray Marine engine. It's a single cylinder ~1910ish engine. The owner says it was running and they were using the boat up till 2006, when they sold their lake property. The boat and engine have been in storage since. It appears to be very complete. There's a FNR transmission installed down past the engine, and then the stuffing box and propeller. Nice brass fuel tank. The engine turns over and has compression, but the oilers and carb would likely need cleaning, of course.
The owners said the Sharpie dated back to the early 70's. It's a camper model with the cabin top hinged at the forward end. There's no tent present in it though. The boat is made out of mahogany. The only rot issue I saw was part of the port chine was a bit rotty on the inside upper corner. Most of the boat was solid. The hull will need recaulked, the deck which is plywood will need stripped and painted or covered. There's two very large nice bronze ports, a bronze bell, and running lights.
The motor seems in unusually decent condition, and its all set up to go.
I'm looking for a project, but this is probably two projects, and not something I'm ready to tackle right now. Very nice couple, they're asking $2,500 for the boat, motor, and trailer. It's located in Southwick Massachusetts. I got their ad off of Facebook. I can email that link if you or someone would like it.
I'll forward a pdf with pictures in another email.
Hope someone gets this that can use it!
All the best,
Michael
Michael can be reached at westfieldriverdoc at yahoo.com
tonni
Username: tonni
Posted on Wednesday, September 10, 2025 - 04:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I stopped by today and checked out a 19' sharpie with a Gray Marine single-cylinder engine from around 1910. The owner said it was running fine up until 2006 when they sold their lake property, and since then it�s been stored. The setup looks very complete � there�s a FNR transmission behind the engine, stuffing box, propeller, and even a nice brass fuel tank. The engine turns over with compression, though the oilers and carb will definitely need a good cleaning. The sharpie itself dates back to the early 70s and is a camper model with a forward-hinged cabin top. The hull is mahogany with only a small area of rot on the inside corner of the port chine, and it will need recaulked. The plywood deck also needs stripped and refinished or covered. It comes with large bronze ports, a bronze bell, and running lights. The motor looks to be in unusually decent shape and is all set up, but overall this is probably two projects in one, and more than I�m ready to take on right now. The couple are asking $2,500 for the boat, motor, and trailer in Southwick, Massachusetts. I can share the Facebook ad and more photos if anyone is interested.
