Robert James Hanson
New member Username: rjh
Post Number: 3 Registered: 09-2006
| Posted on Friday, September 22, 2006 - 08:42 pm: |
Trouble today. I knew the needle valve wasn't set right on our 4 atlantic, so today while we were motoring along (with the motor sort of missing a beat once in a while), I decided I would fool with it and try to get it running better. Of course I ended up closing it too much and it cut out, then no matter what I did I could not get it started anymore. So we proceeded to row the 2 or 3 miles back to the nearest dock. Would an improper needle valve setting cause the motor to 'miss a beat' as I mentioned above, and could someone post instructions on how to set it right? (I can't get it to fire at all now)I read the article 'Antique marine engine tips' and it contains instructions, but I'm not sure that my motor is the same as the ones he's talking about there. (the 4 atlantic we have is only about 15 years old) |
Robert McCleery
Member Username: beardedskipper
Post Number: 8 Registered: 02-2005
| Posted on Friday, September 22, 2006 - 10:27 pm: |
Robert, The Atlantic is very sensitive to the needle valve, so much so that I open it a 1/3 turn when cold starting then close it the same running warm. most common cause of failure to fire is gas/oil in the base, a spoonful will make it completely dead. Drain and you should be back underway Rob |
Post Number: 173 Registered: 07-2002
![](http://www.oldmarineengine.com/discus/messages/thumbnails/95853.gif)
| Posted on Saturday, September 23, 2006 - 06:45 am: |
If you were leaning the mixture, opening it should have allowed it to start right up, maybe a crank or two with it choked. If you were running it rich you could have flooded it. There's a good chance you were trying an adjustment to corect a different problem. Poor ignition will make an engine sound as if it's running rich, leaning will make it kill. Check for a weak battery or fouled ignitor, with the ignitor closed "make and break" the wire to the terminal, it should draw a spark when pulled away. Also open the petcock on the bottom of the carb, water will kill them. Water is heavier than gas and a small amount will stop the flow up the tube, richening or choking will allow it to pull through while running but you can imagine it won't run correctly. |
Robert James Hanson
Member Username: rjh
Post Number: 4 Registered: 09-2006
| Posted on Sunday, September 24, 2006 - 09:49 pm: |
Thanks for the advice gentlemen, I've read about draining the base, but I can't find any kind of plug to remove other than a square plate on the side/bottom of the motor that looks like it's never been removed. Might this be the opening for draining the base ? |
miro forest
Senior Member Username: miro
Post Number: 244 Registered: 11-2001
![](http://www.oldmarineengine.com/discus/messages/thumbnails/11047.jpg)
| Posted on Monday, September 25, 2006 - 02:16 pm: |
I want to echo JB's comments from practical expereince. I went for a couple of years, living with a motor that would start and run OK- sort of. I kept fooling with the carb and the fuel system. But 2 years ago, I refurbished the aspirin tablet sized contact in the ignition timer with a new one, and it was like a new engine - more power, more RPM, better fuel economy. I heard one of the old guys say - 80% of the problems with marine engines is electrickery. miro |
Doug Kimball
Advanced Member Username: doug11k
Post Number: 31 Registered: 12-2003
| Posted on Monday, September 25, 2006 - 08:28 pm: |
Robert, I've recently been helping a friend with a 4 hp make & break Atlantic in a 20' Boston power dory. The originally did not originally have a crankcase drains. We drilled & tapped the bottom of base for 1/4" npt & installed a ball valve. It's been helpful to have it. |
Post Number: 176 Registered: 07-2002
| Posted on Monday, September 25, 2006 - 10:49 pm: |
Don't forget that ignitors can foul just like sparkplugs.The stationary point is supposed to be insulated, if it gets carboned up, the spark will track to ground instead of arcing at the points. Remove it, spray with carb cleaner and brush it off. |
Robert James Hanson
Post Number: 6 Registered: 09-2006
| Posted on Tuesday, September 26, 2006 - 11:58 am: |
Thanks for all the help, we finally got the motor running. We cleaned up the ignitor, filed the points and cleande the whole assembly, and after a little bit of fooling around, she runs perfect. |
