1910 Gray 5hp
Old Marine Engine » One and Two Cylinder Gas Inboards » 1910 Gray 5hp « Previous Next »
david_woodworth
Username: david_woodworth
Posted on Tuesday, October 30, 2012 - 10:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think i have a 1910 Gray marine 5hp its all apart and i need someone i can call or get a copy of instructions to fix it. It has an oiler that is run off the crank shaft in back of the engine. I live in Calif. 661 513 0524 Thanks for your help.
Post Number: 2926
Posted on Wednesday, October 31, 2012 - 05:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Gray engine serial number S1496 denotes a model S(with merchanical oiler) mfgr date 1911.
This illustration is of an R model same as Your model S but with out the mechanical oiler !
Grilus
This is a model S as it came from the factory.
Gs
This photo of the front of a model S with the flywheel off-shows oil lines and fittings.
glines
Post Number: 1582
Posted on Wednesday, October 31, 2012 - 07:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
oops...
The cutaway view at the top is a mid production "U" with flywheel nut instead of a gib key and gear water pump on the front instead of a piston pump on the back.
This is the same model that is in my boat.
Hope this helps
Post Number: 2928
Posted on Wednesday, October 31, 2012 - 09:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This is the Gray Model R that Should have been
posted in above post, its a 1913 but closest illustration that I have !
Thanks Ernie
Gr13
