Vire
Old Marine Engine » One and Two Cylinder Gas Inboards » Vire « Previous Next »
kaumoana
Username: kaumoana
Posted on Sunday, September 19, 2010 - 10:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Attention Vire Owner's
A new website for Vire 7 parts and service.
Vire 7 Marine Engine Parts & Service
260 Adelaide Street East, P.O. Box 200
Toronto, Ontario, Canada M5A1N1
lat/lon 43 39 06.61 N, 79 22 14.04 W
email [email protected]
website www.Vire7MarineEngineParts.yolasite.com
qwilkin
Username: qwilkin
Post Number: 22
Posted on Sunday, September 19, 2010 - 06:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
HELP can anyone help me . I am restoring a BLAXLAND TWIN inboard motor and believe that they also made a three speed gear box for the same engine( FRWD Neutral REV)Can anyone assist me in the whereabouts of such a box ar is there another one that will fit .
QUINTON ( Ballarat Australia)
laurie_d
Username: laurie_d
Post Number: 67
Posted on Sunday, September 19, 2010 - 11:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Quinton, I trust that you know the Blaxlands can run in either direction (though you normally have to hold the clutch forward when running in reverse). About 20+ years ago I had one of those gearboxes that was fitted to a twin. I found it a tad noisy and to some extend it seemed to drain some of the power from the twin. Good tuning and a flick of the magneto just at about stall speed and you'll be going backwards... do not try it when approaching a rock wall or jetty flat out. Regards Laurie
Naik
Posted on Monday, August 13, 2012 - 04:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
We are suppliers of used marine diesel engines and spare parts and we are based in India.
For more details about the stocks, kindly visit our web links at
http://marine-engines-n-spares.blogspot.com
http://shipspares.wordpress.com
If you have any requirement of used marine diesel engines and spare parts, do contact us
Naik
jhershey
Username: jhershey
Posted on Thursday, August 06, 2015 - 02:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have a good source for purchasing:
Ignition coil: Bosch Part Number:- 2 204 211 008 Condenser: Bosch Part Number:- 2 237 330 037 Magneto plate: Bosch Part Number:- 1 217 032 123 Magneto contact breaker points: Bosch Part Number:- 1 217 013 021
