C T Wright help needed
Old Marine Engine » One and Two Cylinder Gas Inboards » C T Wright help needed « Previous Next »
tmann
Username: tmann
Post Number: 11
Posted on Tuesday, August 02, 2016 - 09:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I recently picked up an older C T Wright one cylinder, and am in the process of getting it back in running condition.
Would anybody be able to post a good picture of the original engine badge, and the dimensions of it?
Also need the entire water pump assembly-so any help locating that would be much appreciated.
thanks,
TMann
Post Number: 3839
Posted on Tuesday, August 02, 2016 - 09:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
C.T. Wright marketed many different models of marine engines, some were made in house others were purchased from outside venders and retagged.
Post photos of your engine, probably have some info.
Post Number: 3840
Posted on Wednesday, August 03, 2016 - 02:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
tmann
If you have trouble posting photos here
Click my name at left and Email to me,
I'll post them here and see about some info !
tmann
Username: tmann
Post Number: 12
Posted on Thursday, August 04, 2016 - 09:13 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard, thanks- I did send you a mail and hope it made it.
Don't know if it's my provider or satellite set up, but messages with attachments sometimes go right through, and sometimes not.
tmann
Post Number: 3841
Posted on Thursday, August 04, 2016 - 01:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
tmann's photos
ct1
ct2
ct3
Post Number: 3842
Posted on Thursday, August 04, 2016 - 01:16 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
http://www.oldmarineengine.com/history/WrightCT/WrightCT.htm
Post Number: 3844
Posted on Thursday, August 04, 2016 - 01:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This photo was on line year ago.
ct
primetrucks
Username: primetrucks
Post Number: 66
Posted on Friday, August 05, 2016 - 04:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I HAVE C.T. WRIGHT SERIAL #194 I WILL TAKE SOME PICTURES AND POST THEM. I THINK I HAVE A SPARE EXHAUST MAINFOLD BOX I WILL LOOK FOR IT.}
tmann
Username: tmann
Post Number: 13
Posted on Sunday, August 07, 2016 - 10:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard, thanks for the help. Hope to be able to post a picture of a running engine soon.
Primetrucks, look forward to the pictures. I hope to find a clear image of the original engine badge, and hopefully will be able to recreate one.
TMann
primetrucks
Post Number: 67
Posted on Monday, August 08, 2016 - 10:28 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
here are some pictures
Post Number: 3845
Posted on Monday, August 08, 2016 - 11:45 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
http://www.oldmarineengine.com/discus/messages/9658/130638.html
tmann
Username: tmann
Post Number: 14
Posted on Monday, August 08, 2016 - 11:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Primetrucks, Thanks a bunch for the pictures.
I know someone that works in a shop that uses a 3D printer to make mold blanks.
He's done a couple of engine badges for me in the past out of nylon/plastic.
They work well for pressing the image into either plaster or silicone.
He can also use a picture to create a mold blank, so hopefully this badge will turn out as good as the others he's done.
Appreciate the picture of the pump assembly also.
If you locate any spare parts, or know where they might be found, please keep me in mind.
Again, Thanks,
TMann
