United States Motor Corporation Marin...
Old Marine Engine » One and Two Cylinder Gas Inboards » United States Motor Corporation Marine Engine parts « Previous Next »
captianj
Username: captianj
Posted on Tuesday, August 21, 2018 - 09:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a United States Motor Corporation Marine Engine model # OK-2 that I'm in need of parts for. Piston and connecting rod to be more specific. Any info would be greatly appreciated, thanks.
Post Number: 2474
Posted on Wednesday, August 22, 2018 - 08:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The parts you need are most likely the same as a Model T or Model A Ford car depending on when your engine was made
Hope this helps
