Watkins Motor Co Cinn Ohio
Old Marine Engine » One and Two Cylinder Gas Inboards » Watkins Motor Co Cinn Ohio « Previous Next »
raa
Username: raa
Post Number: 155
Posted on Thursday, July 13, 2017 - 04:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have one of these little fellers? Its missing a water pump. The flywheel is 9" od and is 1.25" wide. looks to be a copy of a Waterman engine but smaller. If anyone has one I would sure like to borrow the pump and make a copy.I assume the two lugs on the rear of the case is where the pump was located.
Dick
p711001
p71102
p71103
p71104
p71105
p71106
jim_parrott
Username: jim_parrott
Post Number: 140
Posted on Friday, July 14, 2017 - 07:59 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dick,
The lugs on the bottom of the cylinder look like they could also be the pivot point for a rowboat motor, but the case looks all inboard???
http://www.cailleoutboards.com/rowboat/waterman/Waterman-1208/pages/IMG_8099.htm l
Jim
Jim
raa
Username: raa
Post Number: 158
Posted on Friday, July 14, 2017 - 12:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A very good point Jim--but it remains how it would have been cooled.The wood support looks original and such could have been in a canoe. Bruce Hall has a complete one and will be sending pictures I hope.
Thanks for the ideas anyhow.
Dick
klanger
Username: klanger
Post Number: 116
Posted on Saturday, July 15, 2017 - 07:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks a lot like this one down under. Don't know the owner.
raa
Username: raa
Post Number: 159
Posted on Saturday, July 15, 2017 - 09:21 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The carb was made by Watkins. I should have posted more pictures.
Watkins carb
Post Number: 912
Posted on Sunday, July 16, 2017 - 04:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It looks like the cooling water inlet is opposite the spigot for the primer.
The output shaft looks short for an eccentric plus a length to attach to a hub for the drive shaft.
Could it be, this is a water pump engine which gets its cooling from the main large pump?
raa
Username: raa
Post Number: 160
Posted on Sunday, July 16, 2017 - 07:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think its only 1 hp. not much of a water pump with 1 hp. I was wondering it it had a Arkansas water pump ie aka per JB the boat moving thru the water forces water up thru the engine
raa
Username: raa
Post Number: 161
Posted on Monday, July 17, 2017 - 10:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce Hall sent pictures of his Watkins but its a 3 hp with a much bigger flywheel with spokes. Its pump appears to bolt to the cylinder casting. Not sure if the pump discharge is by hose or directly into the base.
Dick
jim_parrott
Post Number: 141
Posted on Tuesday, July 18, 2017 - 09:14 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dick
From the pictures, it still looks like an outboard cylinder grafted on to a inboard base. The rear cylinder bolts come up thru the bottom and the front from the top. Every engine in my shop the cylinder mounting bolts go in the same direction. The extra holes in all four corners of the cylinder base, and overlap on the crankcase, indicate the cylinder came off a different motor. An outboard cylinder wouldn't have provisions for a water pump, and the lugs on the back are bigger than needed to mount a pump, indicating it is a pivot point for and outboard. With all that said, a picture is worth a thousand words, but actually being there is worth a thousand pictures.
Jim
jim_parrott
Post Number: 142
Posted on Tuesday, July 18, 2017 - 12:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dick,
After you mentioned the Sweet outboards, I looked them up on Jack Craibs sight and I think I found one that matches your cylinder.
http://www.cailleoutboards.com/rowboat/waterman/waterman-sweet-379/pages/IMG_611 1.html
http://www.cailleoutboards.com/rowboat/waterman/waterman-sweet-379/pages/IMG_612 3.html
bruce
Username: bruce
Post Number: 608
Posted on Tuesday, July 18, 2017 - 10:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sure looks right 2me Jim..
raa
Username: raa
Post Number: 162
Posted on Wednesday, July 19, 2017 - 11:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think Jim has nailed the cylinder assembly. wonder who made the crank castings
Dick
david_woodworth
Username: david_woodworth
Post Number: 25
Posted on Wednesday, October 25, 2017 - 11:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am reluctant to challenge the wisdom of thoes who have posted before me. Like all ignorant people I have an opinion that goes against the tide. I do not think is was ever an outboard motor. Not only is the crank case an issue but the flywheel is to big for an outboard motor.
raa
Username: raa
Post Number: 179
Posted on Thursday, October 26, 2017 - 12:22 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Not to confuse the issue any further I took a water pump and coupling/strap assembly off of a Dispro E1 engine and held it up as shown in the pictures. A simple block with a lug to fit between the cylinder lugs held in place with a pin would work. the crank shaft fit the coupling like a glove.
Watkin motorWatkin motor
jim_parrott
Post Number: 154
Posted on Friday, October 27, 2017 - 09:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
David,
Just the cylinder was part of an outboard, the crank, case and flywheel are part of a unknown at the time inboard motor.
Jim
