Perkins 6354 seized
Old Marine Engine » Diesel Inboards » Perkins 6354 seized « Previous Next »
oscarmcvittie
Username: oscarmcvittie
Posted on Wednesday, May 03, 2006 - 11:14 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
how do i move the pistons on a sunk but drained and filled with diesel 6354 block. the crank will not turn with a big socket and bar ? help.
enginenut
Username: enginenut
Posted on Thursday, June 15, 2006 - 10:30 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Your greatest leverage to turn the engine will be on the flywheel ring gear.Using a bar to pry the engine over tooth by tooth gives tremendous power because of the mechanical reduction involved.I hope you're planning a teardown at least for cleanup.good luck.
George Anderson
Posted on Friday, December 28, 2007 - 08:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What is the valve settings for Perkins 6543 engine?
larry_from_maryland
Username: larry_from_maryland
Post Number: 275
Posted on Friday, December 28, 2007 - 12:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
.012 cold for both intake and ex.
DON CANNON
Posted on Monday, December 15, 2008 - 12:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I HAVE A PERKINS MARINE 6354 THAT IS COMPLETELY SEIZED. THE CRANK WILL NOT BUDGE. THE ENGINE WAS RUNNING FINE WHEN IT WAS SHUT DOWN BUT A RESTART ATTEMPT WEEKS LATER FOUND THE ENGINE SEIZED. I HAVE TRIED A LARGE SOCKET ETC, BUT NO BUDGE. COULD A TRANSMISSION FAILURE COMPLETELY PREVENT THE CRANK FROM TURNING OR ANY IDEAS?
solarrog
Username: solarrog
Post Number: 338
Posted on Monday, December 15, 2008 - 12:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You need to pull the cylinder head and assess the damage. was it low on oil?, signs of water where it doesnt belong? I doubt a transmission lock up would completely seize an engine there would be some small movement. There os always some gear lash.
solarrog
Username: solarrog
Post Number: 339
Posted on Monday, December 15, 2008 - 12:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
is always some gear lash.
I guess I should proof read
DON CANNON
Posted on Monday, December 15, 2008 - 01:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
ROGER,
THANKS MUCH FOR THE RESPONSE. ONE OTHER ITEM: THE OIL LEVEL IS TWICE THE HEIGHT PAST THE FULL MARK. THE LEVEL WAS NORMAL ON THE LAST ONE HOUR CRUISE. THE OIL HAS NOT CHANGED COLOR OR FROTHED. DRAINED SOME SFORM THE SUMP (ONE QUART) BUT DID NOT GET ANY WATER. COULD THW CYLINDERS FILLED WITH WATER SOMEHOW AND WOULD THAT PREVENT ANY CRANK MOVEMENT? THANKS AGAIN FOR THE HELP.
DON CANNON
solarrog
Username: solarrog
Post Number: 341
Posted on Monday, December 15, 2008 - 01:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It would not seize is solid, the engine would be turnable back wards. Have you tried that. Hydro lock will stop and engine from turning over, but generally some air get trapped also allowing for some movement. Im afraid I missed the part as to what type of engine this is. If diesel try to remove the injector to bleed off any fluid in the cylinder, If gas remove the spark plugs. My guess is this is a diesel though. If a socket won't move it in either dirrection, You need to plan a tear down. Even if you break it loose it will most likely self distruct if you run it without checking it out. Engines don't seize without doing damage to some degree.
larry_from_maryland
Post Number: 329
Posted on Monday, December 15, 2008 - 02:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
With the oil leval high it could be diesel dilution. Maybe a cylinder filled with diesel or a cylinder scored from poor oil. You should be able to turn barkwards though. I just went through a sticky engine here myself it would turn backwards but not forwards. The trans had a sprag clutch (lets engine freewheel one way) and the rest of the trans was stuck. I added 8 gallons of diesel to the trans and it unstuck quickly.
enginenut
Username: enginenut
Post Number: 13
Posted on Wednesday, December 17, 2008 - 09:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Don, Don't underestimate the ability of a jammed starter drive to lock the engine fast and prevent rotation in either direction.This always occurs on the starters being energized to startup.Judging from your sequence of events and oil condition, at this point I would remove the starter and try to bar the engine over using a chisel-ended like bar on the individual teeth with the flywheel housing as a fulcrum.The mechanical advantage far surpasses the use of wrench on the crankshaft nut.Good luck and please let us know the outcome.
David Roots
Posted on Tuesday, August 11, 2009 - 07:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Perkins 6-354 marine engine with the wrong dipstick (the marks are in the wrong place for my engine). The possible oil capacity is listed in the manual as between 20 and 52 pints depending on the sump casting type, so I do not know where to put new dipstick marks on my stick.
I assume the oil level limits in all such engines are the same, relative to the crankshaft, with the sump capacity being the only variable.
Can anyone give me measurements from the bottom of the engine casting to the "full" and "empty" marks on their dipstick?
And am I on the right track?
larry_from_maryland
Post Number: 372
Posted on Wednesday, August 12, 2009 - 05:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
No you might not be correct. I have 3 354's and all have differant dipsticks and oil pans. i'll look and see if 2 are the same.
larry_from_maryland
Post Number: 373
Posted on Wednesday, August 12, 2009 - 06:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Well the 2 i checked both have the full mark 1.5 inches below the bottem of the block. The add mark is .5 inches lower. The 3rd engine is setting too far away. One engine is a 1966 the other is 1976.
nigel mills
Posted on Wednesday, June 23, 2010 - 04:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
\hi everyone need some real help here i have two perkins 6354 engines i was out and all of a sudden started getting a knocking noise off my starboard engine we returned to port but had to shut the engine down and used the port engine this then shut it self down.on further investigation we found that some how water got into the desil put clean deisel in and bleed the port engine this engine turns over but the starboard engine just clicks at the starter motor is this seized and if so how do i un seize it can any one help me }}
larry_from_md
Username: larry_from_md
Posted on Wednesday, June 23, 2010 - 12:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Most likely you will have to take apart the sized engine and find the problem. It could be several things,water in the cylinders from a bad head gasket,or broken sleeve or piston or both.
MikeR
Posted on Friday, November 26, 2010 - 06:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Has anyone used a adapter barring tool on a Perkins 6354 to unseize their motor? If so where can someone find one? Thanks
Mark Hourie
Posted on Monday, June 10, 2013 - 10:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi there..I have a ..6354 turbo marine..The turbo has stoped ..And i would like to remove the tubo ....Is there a kit i need..or some tricks. And most of all i supose, is where can i find the parts..i live on the Sunshine Coast ,b.c canada..Thanks for any advise..Mark
