Trying to date a Gray Phantom
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Trying to date a Gray Phantom « Previous Next »
Aaron Miller
Posted on Monday, April 23, 2007 - 08:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Gray Phantom Model number - Ph-6244 that i'm trying to date. If anyone could help me out I would really appreciate it.
JOHN DEBATES
Username: cam_gear
Post Number: 13
Posted on Monday, April 23, 2007 - 09:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Aaron:
Do you have the serial number and is the model
6-244 or 6244
John
Aaron Miller
Posted on Tuesday, April 24, 2007 - 06:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
its a 6244 and the only other number i could find was the engine number which was 61602. if the serial number is something else i'll see what i can do.
Bruce Hall
Username: bruce
Post Number: 138
Posted on Tuesday, April 24, 2007 - 07:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Aaron, My Graymarine serial number list places the serial numbers begining with "6" as 1936. The 6244 suggests 6cyl 244 CI.If a badge on the transmission cover-is it badge shape or more "square"?
JOHN DEBATES
Username: cam_gear
Post Number: 14
Posted on Wednesday, April 25, 2007 - 01:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
AARON, 61602 IS THE SERIAL # 1936 IS THE YEAR.
THE ENGINE MODEL IS SIX-244, 244 CU. IN.
JOHN
Bruce Hall
Username: bruce
Post Number: 140
Posted on Wednesday, April 25, 2007 - 07:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Aaron, I believe it's rated 82Hp at 2400 rpm
