Looking for outlet for some Parts
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Looking for outlet for some Parts « Previous Next »
Richard
Username: rg171352
Posted on Tuesday, May 20, 2008 - 11:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi
I have some old zenith carbs with flame arrestors and a Grey Marine 6 cyl dual carb inboard engine with trans I am looking to sell. Where would be a good place to offer these parts? Is there any sort of demand for any parts than could be garnered from the engine or carbs?
drrot
Posted on Wednesday, May 21, 2008 - 07:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard,
You could post an ad in the classified section. EBAY seems to bring more action. There is a small round tag on Zenith carbs with some numbers on them. Be sure to post the numbers.
John Gauntt
Posted on Tuesday, July 29, 2008 - 01:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I might be interested in the head. Do you know if it is a Phantom-six-104 ?
Post Number: 639
Posted on Tuesday, July 29, 2008 - 05:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Good backfire traps are harder to find than carburetors. IN the Zenith carbs you will find two rings of numbers. The inner ring is a Zenith number and the outer ring is the engine makers name for the model it it was used on.
Robert T Strong
Username: rtstrong
Posted on Saturday, August 16, 2008 - 11:37 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Gray Marine 4 cylinder engine and a lot of parts that I would like to move out of my shop. You can contact me for information and photos @ [email protected]
RON WYLIE
Posted on Tuesday, October 21, 2008 - 02:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I NEED: AN INTAKE MANIFOLD FOR A GRAYMARINE '64 EITHER AMC OR CONTINENTAL FIREBALL / V8 ENGINE (CENTER / SECTION ONLY) CONTACT RON: (760)728-6287
