Gray 4-52
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray 4-52 « Previous Next »
Peter Westfield
Username: martha_green
Posted on Monday, September 14, 2009 - 08:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Gray marine 4-52 engine in my boat. The boat was built in 1965 but I believe the engine is from the late 1950's. It runs good except bad blow by. I am looking for rings, pistons, gaskets etc for a rebuild. Does Anybody know where I might find them? I would also like any additional info on this engine if you have it.
Frank Petran
Username: frank_petran
Post Number: 63
Posted on Tuesday, September 15, 2009 - 08:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Peter,
Google Gray Marine, There should be a firm, Lee Engineering in Conneticut who specializes in Gray Marine. He has or has access to a lot of old records, model numbers etc. Give him a call
Dave A. Rossetti
Username: loopcharged
Posted on Tuesday, August 16, 2011 - 07:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a complete engine. It turns but does not run. I believe the cylinders to be good. 500 OBO
Bruce Hall
Username: bruce
Post Number: 276
Posted on Tuesday, August 16, 2011 - 10:45 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dave, Please post your parts offered in the appropriate Classified section of this site. Thanks. Cheers, Bruce
