Jim Hunt Visitor
| Posted on Friday, January 30, 2009 - 01:00 pm: |
I purchased a Hercules 6 cylindar engine a time back and am trying to find what I have. It has a single updraft carb which may mean it is a KFL. I found a CC serial # that has been ground off and stamped with a new one. It is at the rear right side, under intake manifold. Is there any other place it might be stamped? This could be a hot engine but what can I do? It has been ten years since I found it. |
drrot
Member Username: drrot
Post Number: 16 Registered: 09-2008
| Posted on Saturday, January 31, 2009 - 07:23 am: |
Post a photo if you can. or email them direct to me [email protected] Here is a quick guide to the smaller K series of Chris-Craft converted Hercules engines. Intake and exhaust cast as one ring on face of flywheel about 1/4" high and 2" wide=K 95hp Separate intake and exhaust 1 carb ring on face of flywheel about 1/4" high and 2" wide=KL 105hp Separate intake and exhaust 1 carb flat face on flywheel= KLC 120HP Separate intake and exhaust 2 updraft carbs flat face on flywheel= KFL 131hp Separate intake and exhaust 3 downdraft carbs flat face on flywheel= KBL 131hp It is common to chance the serial number on engines to match the old one when swapping engines. There is also a small dime size tag on the Zenith carb with numbers on it. I can run those numbers to see what engine the carb was made for. |
bing
New member Username: bing
Post Number: 1 Registered: 01-2009
| Posted on Saturday, January 31, 2009 - 11:55 am: |
It looks like the intake and exhaust manifolds are 2 pieces. The flywheel is flat. The carburator tag reads 11168A. Someone did a pretty poor job of stamping of engine because the numbers are almost impossible to read. Thanks again |
drrot
Post Number: 17 Registered: 09-2008
| Posted on Saturday, January 31, 2009 - 01:20 pm: |
11168A is from a Chris-Craft KLC |
tollycraft
New member Username: tollycraft
Post Number: 1 Registered: 08-2009
| Posted on Sunday, August 23, 2009 - 11:29 pm: |
I have 64 tollycraft with a interceptor engine #ncd22r31720 this is on the timming cover, I am trying to find out the size of the engine, so I can get the rebuild gaskets to give to a mechanic. please help, Thankyou |
tollycraft
Post Number: 2 Registered: 08-2009
| Posted on Monday, August 24, 2009 - 07:02 pm: |
Would there be a website or how I can decode and get all the specs for a marine engine interceptor off a tollycraft 64 17ft inboard engine, this is the number on the engine timing cover #ncd22r31720 thanku |
