Paragon transmission issue |
busboy
Member Username: busboy
Post Number: 4 Registered: 12-2015
| Posted on Sunday, November 04, 2018 - 07:32 am: |
is there any "special" tricks to know when removing paragon transmission fro gray 620 |
ned_l
Senior Member Username: ned_l
Post Number: 182 Registered: 08-2012
| Posted on Wednesday, November 14, 2018 - 12:40 pm: |
It should be straight forward. Drain the whole engine crank case, remove all the flange bolts between the reverse gear and the rear bell housing, pull the reverse gear 'aft' off the stub shaft. Never did it on a 620, a Gray 109 a couple of times though. |
