allan_lambert
New member Username: allan_lambert
Post Number: 1 Registered: 08-2007
| Posted on Sunday, September 02, 2007 - 09:43 am: |
My old 14Ft boat has an Albin engine, cant see any ID plate saying what model it is. It has always been hard to start and now wont fire up at all even using Easy Start, checked spark/petrol and that seems ok. So it looks like I will need to repair or replace it. I'm looking for same motor in working order and or spare parts and gaskets if any one has any info it will be appreciated I have a photo but size is to big (500Kb) to post,working on shrinking it Thanks Allan Lambert Aust |
allan_lambert
Post Number: 2 Registered: 08-2007
| Posted on Monday, September 10, 2007 - 07:39 am: |
Photo of my Albin engine which i trying to find parts for, ref my earlier post |
mvictor_be
Member Username: mvictor_be
Post Number: 15 Registered: 05-2007
| Posted on Monday, September 10, 2007 - 08:16 am: |
Albin 021 Twin cylinder, 10 horse power petrol 8 horse power paraffin Ignition system, Magneto Coili Cooling Raw water. Gear type water pump Electrics,12 volt Dynamo + starter motor (enclosed flywheel) Dynostart (belt drive). Tip: DO NOT exceed a 60 AHR battery Parts and support http://www.forsmarin.se INSTRUKTIONS: http://www.forsmarin.se/albin/reskat/Kompletta/O11_O21_ins_eng.pdf PARTS http://www.forsmarin.se/albin/reskat/Kompletta/O11_O21_res_sve_eng.pdf |
allan_lambert
Post Number: 3 Registered: 08-2007
| Posted on Tuesday, September 11, 2007 - 02:14 am: |
Victor, Thanks very much for the info, My engine looks like an 021 model but has some differences to the info you sent,Starter motor is 6 volt and has a full housing around the fly wheel and maybe some other differences, no coil? I'm away working in Malaysia until next month so will have good look when i get back. Do you know if all parts are available, at the least a manifold,carburetor and caskets for same. |
mvictor_be
Post Number: 16 Registered: 05-2007
| Posted on Tuesday, September 11, 2007 - 07:50 am: |
Hi Normaly you have a bras carburator, it can be a newer model also like the one on the O22 in most cases if there is a coli the magneto is not working as it has to be and the coli provide the spark is cheeper than replace the magneto and it works. there are models that have the housing around the are more rare here in europ i think its the combi |
mvictor_be
Post Number: 17 Registered: 05-2007
| Posted on Tuesday, September 11, 2007 - 08:02 am: |
I make the gaskets myself For parts send me a poto from the parts you need http://homepages.which.net/~j.stanton http://www.dehaanjachttechniek.nl http://www.debruynwatersportservice.nl
allan_lambert
Member Username: allan_lambert
Post Number: 4 Registered: 08-2007
| Posted on Tuesday, September 18, 2007 - 12:47 am: |
Victor, Thanks again, I will wait until i get back to Aust in a couple of weeks.are you associated with Forsmarin?, I'm sure I will looking for parts or another motor of the same model as it will be to hard to change engine type in my boat and i like the old albin 2cyl. Still not sure why mine is a 6 volt system and not 12 volt like the manuals say. |
nrorke
| Posted on Tuesday, September 18, 2007 - 05:38 pm: |
Hi, I have an Albin 011 installed in my 1936 Blackwater Sloop in Devon, England. It has provided me with good service since about 1989 when I first installed it, having bought it at an auction. It looks very like the one in the photo. I have an owners manual I could copy and e-mail if needed. |
allan_lambert
Post Number: 5 Registered: 08-2007
| Posted on Wednesday, September 19, 2007 - 07:20 pm: |
Nick, Thanks for info. I think my engine is an 021 though its a bit different from the feedback I'm getting. I have a manual which covers 011 and 021 which I downloaded from the sites that Victor gave me. My boat is nothing fancy just an old 14ft timber launch but I have become quite attached to it over the years. My only problem is there doesn't seem to be any one in Aust with any parts. |
Phil Edge Visitor
| Posted on Sunday, September 23, 2007 - 03:26 pm: |
There is a guy in the UK called John Stanton that I think has parts for the 011 and 021. His number is 01590 681848. I've just got an old 011 running which will be overhauled and put back in the boat it came from, so I'll hopefully be getting parts from him myself. |
mvictor_be
Post Number: 18 Registered: 05-2007
| Posted on Sunday, September 23, 2007 - 03:41 pm: |
Hi nrorke , i have a original copy from the engine thanks for the offer, victor |
Robert Strabird
| Posted on Friday, October 12, 2007 - 11:43 am: |
I have an Albin 2 cylender in my Columbia 36' The flexible exhaust cuppling between the block and the muffler is leaking. Does anyone have experience finding replacement parts for the exhaust? Bob |
Steve Mallett
| Posted on Friday, July 30, 2010 - 07:14 pm: |
Hi. I am an Englishman living in Sweden. I own a sailing cruiser with a 011 Albin. This company has helped me a lot... Hope it helps Steve http://www.albinmotor.com/AlbinMotor/english/index.html |
Dave Scott
| Posted on Monday, June 23, 2014 - 02:23 pm: |
Hi, I'm looking for a starter or the original Bosch starter motor for a 1971 Albin AD 21. Diesel engine My E address is CJS1872@gmail.com PH. # 858-568-6982 Thanks so. |
