Today's Trivia
Old Marine Engine » One and Two Cylinder Gas Inboards » Today's Trivia « Previous Next »
Post Number: 1909
Posted on Tuesday, December 09, 2014 - 09:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Trivia for today
What is it?
Depending on how specific you are there could be more than one answer
Post Number: 3414
Posted on Tuesday, December 09, 2014 - 11:14 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Pzr1
dave_carter
Username: dave_carter
Post Number: 18
Posted on Tuesday, December 09, 2014 - 04:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Anything Acme related?
Regards,DJC
Post Number: 1911
Posted on Tuesday, December 09, 2014 - 04:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
No closer the other end of the alphabet.
dave_carter
Post Number: 19
Posted on Tuesday, December 09, 2014 - 04:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Any connection with R.R.?
Regards, DJC
seagal007
Username: seagal007
Post Number: 23
Posted on Tuesday, December 09, 2014 - 04:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
T head Palmer
marion
Username: marion
Post Number: 8
Posted on Tuesday, December 09, 2014 - 05:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Crankcase for Palmer Tee-head with two outboard camshafts.
dave_carter
Post Number: 20
Posted on Wednesday, December 10, 2014 - 09:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A "non-specific" question seeking an "alternative" answer.
Any connection to the failed skulduggery,on behalf of W.E.Co�.(?), supported by Acme, wanting to gain hold of some of R.R.s assets?
Great engine all the same.
Regards,DJC
Post Number: 1912
Posted on Wednesday, December 10, 2014 - 09:33 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is another one.
I have no idea if this engine ever got put back together as I sold it the way it is here and have not heard back from the person that bought it.
http://www.oldmarineengine.com/discus/messages/3430/1066.html
Post Number: 1913
Posted on Wednesday, December 10, 2014 - 09:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dave,
I don't think so.
Post Number: 1914
Posted on Wednesday, December 10, 2014 - 12:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Just to show the actual size of a Palmer ZR 1
If it was a 6 cylinder engine it would be 855 cu in or over 14 L
This is 142.5 cu in or 2.335 L per cylinder.
Post Number: 1915
Posted on Wednesday, December 10, 2014 - 12:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
More Trivia
This crankcase could have been a ZR1, PNR1, or NR1. This one is an early ZR1. Based on tag location (on the intake cam gear housing), number of crankcase breathers (1)and the casting around the oil fill at the top of the exhaust (right side) timing gear area.
I have all the parts to make this one run again.
If time allows that should happen over the winter.
