GRAYMARINE 136
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » GRAYMARINE 136 « Previous Next »
david brown
Username: woodman
Posted on Saturday, October 07, 2006 - 08:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can anyone tell me the following info. re; GRAYMARINE 136 please.
(1) max rpm, (2) cruise rpm, (3) torque and weight in lbs. (inc. gearbox,direct drive + astern)
Douglas J. Beattie
Username: gannet
Post Number: 9
Posted on Saturday, October 07, 2006 - 07:41 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
David
this engine is rated at 136hp. at 3600 rpm. It weighs 825 lbs. and they don't mention torque, but you can figure that out. Cruise rpm is another thing that is vessel specific.
JOHN DEBATES
Username: cam_gear
Posted on Monday, October 09, 2006 - 09:40 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
DAVID
IS THE ENGINE A V8A-136?
IF SO IT IS 215 CU.IN. ALUMINUM
9:1 COMPRESSION RATIO
POWER RATING 136 HP @4500 RPM
INTERMITTENT RATING 105 HP 4300 RPM
DRY WEIGHT 470 LBS
WET WEIGHT 501 LBS
BORE 3.500"
STROKE 2.800"
CARBURETOR ROCHESTER 2-BARREL, SPEC. 7020992
FRESH WATER TEMPERATURE 190 F.
JOHN
Hakan Pettersson
Username: hugger69
Post Number: 29
Posted on Thursday, September 01, 2011 - 07:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have any pics of this 215 cui V8 from Gray??
I miss the carb to this engine from Rochester 2 Jet 7020992!
